Thanks for the feedback everyone, I made some quick alterations as you all seemed to agree I had overkilled it
. The engines are now a little larger but there is only 2 of them, as for the pod I have smoothed it out a little and changed the shape very slightly. I will hopefully add some more detail when I have time.
Front part of the engines look low fidelity compared to the back, simple bevel/extrusions with very clear polygons showing. Where as compared with the rear (Tehe), which looks much more complex and higher fidelity. Why not throw some more polygons at it.
I slightly agree with Alex too about the cockpit, but I do like the design, I would say replace the front part of the pod (The 2 front wings) with something else... Like intakes or mini jets or something.
Also keep in mind F1 cars are designed to stick to the ground... This thing is floating..
Edited by Jestersheepy, 10 October 2011 - 03:26 PM.
